Progress bar and Status bar
Hi there,
Since the progress bar is inside the status bar, it’s not displayed if the status bar is disabled.
Is it possible to register a callback or event in RhinoCommon or RhinoWindows to be notified on changes?
Thanks in advance.
Will
Hi @Harper
Are you disabling the status bar? If so, how?
– Dale
Hi @dale ,
Yes, setting the property Rhino.ApplicationSettings.AppearanceSettings.ShowStatusBar to false.
Regards
Will
Hi @Harper,
Try hooking the RhinoApp.AppSettingsChanged event.
– Dale
Hi @Dale,
Thanks for your answer, this event is raised every time a setting is changed (OSnap, etc…) so is it possible to get the Rhino progressbar current value from here?
Will
Hi @Harper,
No, not at this time.
– Dale
Hi @dale,
Ok got you, thanks anyway!
Regards
Will
