I would like to program a new geometry. Its name would be ‘Graph’ and it represents a visible graph on the rhino viewport. Like the other rhino geometries I want it to have its own commands. In certain way it would be like a curve geometry, in which there wouldbe posible to connect more than two lines for each node.
I would like to use this geometry as reference in grasshopper, too.
I developed something like this and you don’t need geometry at all, just information. Well, I preferred like that bc I can automate their positions using a simple particle system, but you can do it with geometry, I guess.
For my case, I use a DisplayConduit to visualize it and if you want to interact with it in rhino scene you need a MouseCallback and do all the logic.
For GH it’s different, you have to create the GH wrap of your data type (which inherits from GH_Goo) and a parameter that receives this, and also, override the display methods.
Thank you, the second link is useful to me.
I can code simple stand-alone programs in c#. But this is different.
I mean, I´d have to anchor it to the rhino-app in some way, I am right?
Thank you, but it wouldn’t work for me. Imagine it like if it were a pipe-system embebed in a building´s structure. Or a neuron circuit in a model of an insect.
It has to be integrated with the view. For the purpose of rendering it could be converted to curves, the graph manteining the structure.
