The example https://developer.rhino3d.com/samples/rhinocommon/add-material/ shows how to programmatically create materials. It works, as-is, however if you omit assigning the material to the sphere, it doesn’t work (on Mac, haven’t tried Windows). The material never shows up in the materials list. The material is added to the table, so I would expect it to stay there until it’s removed/deleted. Did I miss something in how materials work in Rhino?
partial class Examples
public static Rhino.Commands.Result AddMaterial(Rhino.RhinoDoc doc)
// materials are stored in the document's material table
int index = doc.Materials.Add();
Rhino.DocObjects.Material mat = doc.Materials[index];
mat.DiffuseColor = System.Drawing.Color.Chocolate;
mat.SpecularColor = System.Drawing.Color.CadetBlue;
mat.CommitChanges();
// set up object attributes to say they use a specific material
// Rhino.Geometry.Sphere sp = new Rhino.Geometry.Sphere(Rhino.Geometry.Plane.WorldXY, 5);
// Rhino.DocObjects.ObjectAttributes attr = new Rhino.DocObjects.ObjectAttributes();
// attr.MaterialIndex = index;
// attr.MaterialSource = Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject;
// doc.Objects.AddSphere(sp, attr);
// add a sphere without the material attributes set
// sp.Center = new Rhino.Geometry.Point3d(10, 10, 0);
// doc.Objects.AddSphere(sp);
doc.Views.Redraw();
return Rhino.Commands.Result.Success;
For the material to show up in the materials list in Rhino, you need to create a RenderMaterial.
var name = "Chocolate/Blue!";
var idx = doc.Materials.Find(name, true);
if (idx < 0)
var mat = new Material();
mat.Default();
mat.Name = name;
mat.DiffuseColor = Color.Chocolate;
mat.SpecularColor = Color.CadetBlue;
idx = doc.Materials.Add(mat);
// after adding a *render* material, it will show up in the materials table in Rhino.
var rm = RenderMaterial.CreateBasicMaterial(doc.Materials[idx]);
doc.RenderMaterials.Add(rm);
