Programmatically Change Grasshopper's Library Path
Hi All,
I’ve been poking around the dotnet version of Rhino.Inside with Grasshopper from GitHub for a while and it’s amazing!
However, I was wondering whether it would be possible to override the plugin library path while GH is loading. You can image a scenario where I’m programmatically loading Rhino.Inside with GH to test a different plugin version than the default one and would want to programmatically load the plugins from a different location only for this particular instance of GH.
I could image this as function in Rhino which would allow me to set the Grasshopper Developer Settings before an instance of GH is started:
var pluginObject = Rhino.RhinoApp.GetPlugInObject("Grasshopper") as Grasshopper.Plugin.GH_RhinoScriptInterface;
pluginObject .SetGrasshopperDeveloperSettingsLibraryPath("CustomLibraryPath"); //something like this
pluginObject.RunHeadless();
Any chance something like this exists ?
Thanks in advance!
Marcin
