Processing added and deleted objects in my plugin
Hello! These are snippets of my model, view model and view, I am trying to keep track of all points that are currently in the rhino doc, my view model is in charge of adding objects to the model´s queues based on rhino add and delete object events, what I am not sure about is if this is a right approach, how to process the queues, do I use an async task? do I run another thread? do I trigger the queue processing by another event? I am very much new to csharp so I want to be careful about choosing next steps and Id like to get some advice from more experienced developers. The list of points is what I would like the viewmodel to watch and expose to my view but I am struggling to glue everything together. any advice is greatly appreciated, thank you
    public class MyPoint
        public string Id { get; set; }
        public string X { get; set; }
        public string Y { get; set; }
        public string Z { get; set; }
// Model
    internal class ObjPoints
        List<MyPoint> points;
        public List<MyPoint> Points
            get { return points; }
            set { points = value; }
        Queue<RhinoObject> addedObjs;
        public Queue<RhinoObject> AddedObjs
            get { return addedObjs; }
            set { addedObjs = value; }
        Queue<RhinoObject> deletedObjs;
        public Queue<RhinoObject> DeletedObjs
            get { return deletedObjs; }
            set { deletedObjs = value; }
        public ObjPoints()
            points = new List<MyPoint>();
            addedObjs = new Queue<RhinoObject>();
            deletedObjs = new Queue<RhinoObject>();
        public HashSet<Point3d> ObjectToPoints(RhinoObject obj)
            var geometry = obj.Geometry;
            List<Point3d> controlPoints = new List<Point3d>();
            HashSet<Point3d> resultSet = new HashSet<Point3d>();
            if (geometry is Brep brep)
                foreach (var vertex in brep.Vertices)
                    controlPoints.Add(vertex.Location);
            else if (geometry is Surface surface)
                var nurbsSurface = surface.ToNurbsSurface();
                for (int i = 0; i < nurbsSurface.Points.CountU; i++)
                    for (int j = 0; j < nurbsSurface.Points.CountV; j++)
                        controlPoints.Add(nurbsSurface.Points.GetControlPoint(i, j).Location);
            else if (geometry is Curve curve)
                var nurbsCurve = curve.ToNurbsCurve();
                for (int i = 0; i < nurbsCurve.Points.Count; i++)
                    controlPoints.Add(nurbsCurve.Points[i].Location);
            else if (geometry is Point point)
                controlPoints.Add(point.Location);
            if (controlPoints.Count > 0)
                resultSet = new HashSet<Point3d>(controlPoints);
            else
                RhinoApp.WriteLine($"Failed to get control points of object {obj}");
            return resultSet;
// View model
public class MainViewModel : BaseViewModel
    ObjPoints objPoints;
    ObservableCollection<MyPoint> _points;
    public IEnumerable<MyPoint> Points => _points;
    public MainViewModel()
        RhinoApp.Idle += OnIdle;
        RhinoDoc.DeleteRhinoObject += OnDeleteRhinoObject;
        RhinoDoc.AddRhinoObject += OnAddRhinoObject;
        _points = new ObservableCollection<MyPoint>();
    private void OnAddRhinoObject(object sender, RhinoObjectEventArgs e)
        RhinoApp.WriteLine("Adding object");
        var obj = e.TheObject;
        objPoints.AddedObjs.Enqueue(obj);
    private void OnDeleteRhinoObject(object sender, RhinoObjectEventArgs e)
        RhinoApp.WriteLine("Deleting objects");
        objPoints.DeletedObjs.Enqueue(obj);
    private void OnIdle(object sender, EventArgs e)
        //RhinoApp.WriteLine("Rhino Idling");
// grid whose data should be bound to my view model
var grid = new GridView { ShowHeader = true, DataStore = v_model.Points};
CommonViewFuncs.AddGridColumn<MyPoint>(grid, "Point_ID", (p => p.Id));
CommonViewFuncs.AddGridColumn<MyPoint>(grid, "Coord_X", (p => p.X));
CommonViewFuncs.AddGridColumn<MyPoint>(grid, "Coord_Y", (p => p.Y));
CommonViewFuncs.AddGridColumn<MyPoint>(grid, "Coord_Z", (p => p.Z));
internal static void AddGridColumn<TItem>(GridView grid, string headerText, Expression<Func<TItem, string>> propertySelector)
    var col = new GridColumn
        HeaderText = headerText,
        DataCell = new TextBoxCell { Binding = Binding.Property(propertySelector) },
        AutoSize = true,
        Editable = false
    grid.Columns.Add(col);
Hi @Vojta_Hanzlík,
When you detect an event you need to process, set a flag, or in your case add to some kind of event queue, an then hook up a RhinoApp.Idle event handler.
The RhinoApp.Idle handler is called unhook the event handler and process your queues.
– Dale
Hi @Vojta_Hanzlík,
Something to look at …
PointsViewModel.cs (10.1 KB)
– Dale
