Process Rhino Inside Revit toolbars permanently disappear
Hello there, as you can see, some toolbars still appear at launch, after regular closing of course.
Is there a right way to permanently close them ? Is this a glitch ?
Thanks for the help
Hi Thomas,
Its most likely a plugin conflict of some sort (this is the only report). To troubleshoot try removing all Addins and add them back in one by one.
Revit 2025.3 ships with an addin manager.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-648D9DD3-3933-4105-AB48-90A5D10FA8D0
Mhhhh, okay, I can try that.
Has the conflict problem with Enscape been fixed ?
Recent reinstall, now I get this
Object: Save (level 1)
Exception has been thrown by the target of an invocation.
TargetInvocationException
Object: Save (level 2)
Could not load file or assembly ‘System.Drawing.Primitives, Version=7.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ or one of its dependencies. The system cannot find the file specified.
FileNotFoundException
Object: Bake (level 1)
Object: Bake (level 2)
Any idea ?
To troubleshoot you’ll need to isolate and bring back the 3rd party addins one by one. Once found please contact the developers, its typically an older version of Opennurbs.dll they are loading.
Also ensure that you have the latest version of the 3rd party addins.
Found it, Rhino Inside Revit conflicts with the Speckle Manager.
I uninstalled the all SPeckle manager and it’s solved.
I wonder what is the specific glitch
Thanks for the update, the last time i loaded speckle it was fine. I’ll see if can repeat.
Revit 2024 Rhino 8
Speckle manager Grasshopper Rhino Revit
Everything is looking OK so far (Revit 2025 & 2024), are you running the Grasshopper and Rhino Speckle manager plugins as well?
Installed both, no errors but they do put a note into the command line that Rhino.Inside is not supported.
