I just bought a macbook M1 Pro 2021 a few months ago.
Since the last Update Rhino got really slow. There are so many Lags. I just tried the File on another Macbook pro(2019). There were no lags. Is there an actual Problem that Rhino isn’t optimize to the new Macbook?
Maybe someone had an idea
Hi Niklas -
Which update is that?
Also,
i Think its the 7.14 or 7.13.
So it’s not sure if it will run better in the next few months ?
Hi Niklas -
We can’t be sure, no.
Let’s see - You are now running 7.15?
Could you try running 7.13 again and see if that is better? (Note, on Mac, when running the *.dmg, instead of unpacking into the applications folder, you can drag the application to the desktop. That way, you can quickly test several versions).
Hi Wim,
is there a manual how i could install an older Version of Rhino ?
