Problems with TextObjects in Blocks
Hi @Dan, thanks for letting me know! No worries, I am just experiencing weird behavior within blocks…
Can please you describe this in enough detail that I can reproduce it on my computer?
The behaviour here is a bit unpredictable though…With Helvetica Neue family, and now I can see it even for the text, not in the block, it sometimes jumps back to the regular Helvetica font. I can´t see any rule, it just happens every now and then. Occasionally, I must hit fe. the font I want to define the text to many times till it changes - I tried to cover it in the video https://aws1.discourse-cdn.com/mcneel/uploads/default/original/3X/9/9/9973662cf7812fca853c3d71e056fa6af946aa8b.mov
I can’t reproduce any issue regarding the font in the block right now, but I found out the following. When I create a template including a block, the new template has doubled the block when editing. See the attached video. https://aws1.discourse-cdn.com/mcneel/uploads/default/original/3X/4/e/4ed4980583bfdb4fa3abf2d8e40c5051d2a83644.mov
TO reproduce - 1) create block 2) save as template 3) open new with template 4) try to edit the block
Hello - so far I cannot reproduce what you are describing… but I confess the first video is quite hard to follow.
