I have compiled and successfully run the examples i.e. example_read.
I have created my own function based on the example called
int readNurbs(const wchar_t *name);
and also sucessfully tested this with a command line program.
But when I try and use readNurbs under FreeCAD non of the Nurbs functions show up in the FreeCAD console. If I code std::cout << “test” or std::cerr << “test” these show up in the FreeCAD console but not dump.Print(“test”);
In the test command line program I wrote if I change a std::cout << “Trace” to std::wcout << Trace. It also stops any further output from the OpenNurbs functions.
Sorry but you don’t seem to understand, but I am trying to use opennurrbs in a FreeCAD importer as a result. FreeCAD redirects stdout and steer to its console. Trouble is opennnurbs output does not appear anywhere
What I am saying is that openNURBS does not output anywhere. The fact that example_read.cpp is writing to the console is just because it is an example…
