When I import a DWG file into Lands design (even with the bamboo park tutorial), and try to use the LaZonify command, then “pick inner points”, I click inside a closed boundary of 2D curves but the only thing that happens is _-Hatch appears in the command line. There is no zoning dialog box appearing or anything else.
Hi @impermanator are you using Lands Design Beta VI version? there was a bug in previous Beta that didn’t let you insert zones by a “pick inner point” method.
Now, make sure the area where you click inside has a closed boundary. If problem persists, please send us a copy of that model to landsdesign@asuni.com indicating the area where you want to insert the zone.
