i have probelms installing K2 Engineering…
I did everything as usual and still no success.
According to this page, i have to install Kangaroo2 (which i did) aswell as plankton. (I did)
But: Grasshopper will not recognize the K2 plug-in! Any Ideas?
Did you download the K2Engineering.gha file under the “releases” tab on Github?
Did you include the .dll and .gha files for Kangaroo2 and plankton? Unblocked all of them of course?
Which version of Rhino are you using?
Thank you, i thought i could use the .csproj or .sln file instead of a .gha… because i did not find the .gha on github. (Which I did now, so everything worked for me)
I recently faced an issue when installing K2Engineering on the new Rhino 8. I tried to perform loading plugin one by one command and it seems that the plugin loaded just fine. But for some reason, the plugin just not showing. It was also working flawlessly in rhino 7 or 6. Can you provide some suggestion?
