Problems with curve continuity and normals in loft
Hello, I am trying to create a lofted surface from a line. I can’t manage to create 2 clean, closed curves and the result seems to consist of 2 surfaces with opposite normals. I guess this is a trivial matter but I don’t get what I’m doing wrong. Any help please?
test loft continuity.gh (90.3 KB)
With only your screenshot, I guess you could try to flatten your Join Curvesinputs.
It is the solution, however I’m surprised the output is a list and not a tree…
missing
This looks more complex than your post made it sound:
Finding the relevant part, I see much more complexity than needed.
loft continuity_2023Mar14a.gh (92.3 KB)
Yes, thank you. The rest of the loft is not clean yet but I guess I have to constrain it with guide lines
What do you mean by “not clean” and “constrain it with guide lines” ?
This is a simplified version to get the same result, which unfortunately is a polysurface (“Open Brep”) instead of a single surface. Not sure how to fix that…? :thinking:
loft continuity_2023Mar14b.gh (9.3 KB)
Here is a way to get a single surface:
loft continuity_2023Mar14c.gh (12.4 KB)
If you relocate your curve seams like this,(mind symmetry)you could get an untrimmed surface…
test loft continuity_re.gh (10.8 KB)
Great! Thanks all for the help :slight_smile:
