Hello.
I Installed Rhino.6 (evaluation version).
When I try to draw, the image disappear and doesn´t stay in the screen
I Unistalled ans installed several times but keeps happening the same thing
Thank you for your help in advanced
I suspect you are running old graphics drivers that are not working correctly with OpenGL.
In the Panels pull-down menu, enable the Notifications panel.
Is there a message about updating your display drivers?
If so, follow those links to get them updated.
Any luck?
Thank You very much
I updating my display drivers but not was solutioned.
When I installed, I have two Rhinos version (one of them called “open in security mode”)
The normal Rhino doesn´t keep the draw.
The security mode doesn´t keep the draw but doesn´t render the figures.
Its because I installed in cloud mode the first time?
Thank you in advance for your help
Sorry y would like to say:
The security mode: keep the draw but doesn´t render the figures.
Thank You very much
render the figures.
Libre de virus. www.avast.com
Hello - please run the command SystemInfo
in Rhino and copy/paste the results here.
Rhino 6 SR18 2019-9-23 (Rhino 6, 6.18.19266.14201, Git hash:master @ 3d84f88dec99b2f4e8b7497e739ed2adc2ba8ef6)
License type: Evaluation, revisión 2019-09-23
License details: Stand-Alone
Expires on: 2019-12-29
Windows 8.1 (Physical RAM: 16Gb)
Machine name: JDASH
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 4600 (Intel) Memory: 2GB, Driver date: 11-15-2013 (M-D-Y). OpenGL Ver: 4.3.0
Secondary graphics devices.
NVIDIA GeForce GT 750M (NVidia) Memory: 4GB, Driver date: 10-28-2013 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.3
Shading Language: 4.30 NVIDIA via Cg compiler
Driver Date: 10-28-2013
Driver Version: 9.18.13.2762
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.18.19266.14201
thank you in advance
Hi - your GPU drivers are from 2013. Aren’t there more up-to-date versions for your cards? The notifications panel in Rhino should provide links to the web pages where you can find the correct drivers.
The Intel card is set to be the primary OpenGL device. Please go into the NVIDIA control panel to change this.
Thank you very much John, Pascal and Wim.
Finally updating NVIDIA, Rhino works
Thank you for all
Jorge
