Problems offseting crv on srf (solved)
can anyone help ive built this srf with sweep 2 and when offsetting crv on srf the end arrow is in the wrong direction reulting in an odd offset. ive tried flipping direction but no luck. any help would be appreciated - thanks
Please share your file.
Without the .3dm file I can only guess.
Are you offsetting the edge, or a seperate curve.
If offseting the edge try RebuildEdges
If a separate curve then the curve is likely to be folded back on itself near the end.
Run CrvStart and CrvEnd (Alternative is run Divide with MarkeEnds=Yes and 1 Segment.) This will place points at the ends of the curve. Result should be similar to this:
Zoom in on the end to see if the visible curve extends beyond the end.
Turn on control points. If the curve is folded then there will be a control point beynd the curve, with the curve end control point coinciding with the point at the actual end of the curve.
Rearrange the control points so that the curve ends where needed without folding.
Hey David. That’s exactly it thanks so much for the detailed help! I really appreciate the time taken to reply!
You can click in a box to mark this as “Solved”.
