I`ve downloaded the last version of Rhino for mac and I have a big problem trying to change the options in all the curve commands, I can’t change the radius in fillet command, I can’t change the line mode from straight to curve. Do anyone have a solution for this problem?
Hi Martin,
Is it that you can’t type in the field for the options when running these commands or that you don’t see the options at all? If it’s the latter, make sure you have the absolute latest Mac Rhino build available (499). There was an issue with the command options not being visible when running OSX 10.8 that got fixed.
