This usually only happens when you have either huge numbers of objects or objects with huge numbers of sub elements (like polylines with many thousands of points)… Are either one of those the case? Does this happen with simple objects as well? Never had it hang for 10 minutes though, usually I esc out before that…
Hi Cosmas - can you export an object that gives trouble and post it here if it does it all by itself? Are you sure the selected object is not grouped with a pile of other, hidden, stuff?
I drew a single line, confirmed that what brought up “Processing objects. Press escape key to abort” and exported it to the attached file. Still brings up the same thing.
It does… now, but I’m pretty sure it wasn’t last week. Since nothing’s changed, I assume that I didn’t notice it which is hard to believe. Will keep an eye on it, Pascal. Thank you.
