Problem with the Islamic Gradient Pattern
I’m trying to create this pattern in Grasshopper using the script I received, but the result doesn’t look like the reference. How can I make it look like the reference? What’s missing so that the pattern looks like the reference? The pattern lines I created are offset; I need to make them solid. The blue lines that I’m working on—can anyone help me? And if anyone has the full script, could you send me this exact pattern? Thanks in advance.
Upload your Internalized file .
It seems that you are using a plugin based on your algorithm screenshot , consider to internalize that part too .
Hi ,
I see that you’re using Parakeet plugin which is a good idea. This is the way I made something similar to your referenced image . Changing the Graph Mapper value will lead to different distribution patterns .
Islamic_Pattern.gh (28.3 KB)
