Hi, i have a problem with the surface i want to analyze, the color looks blurry and when i orbit the model it changes, so i want to the surface to be like the second image, please help
Hi -
You should probably hide the object in Rhino if it is referenced in Grasshopper or disable the preview of instances of that object upstream on the Grasshopper canvas.
Note that for questions related to the Ladybug Tools, you should look at https://discourse.ladybug.tools/
thank you Wim, i found the solution in Visualisation problem sun analysis - ladybug-tools - Ladybug Tools | Forum
