I have a small problem with the toolbars. When I left click on icon which has a sub-menu type line, cube, etc … that is to say, the vast majority of icons and this one systematically opens the submenu. In short it happens the same thing when I make a left click or a right click on an icon. Can someone please help me?
PS : I use Rhino 5, and I’m french sorry for my english.
Hello - do you mean that no command runs, only the cascading toolbars?
But, if there is a command assigned to the top level button, which is the usual, then click-and-release on the button will run the command, and click-and -hold will cascade the toolbars. Does that make sense with what you are seeing?
Yes I understand what you mean. In fact no matter how I click, it always opens the cascade while in the tutorials that I made a left click throws the command of the main icon or me it opens the cascade and it is not very convenient. I do not have the possibility to directly launch the command of the main icon. For example if I want to make a cube, I click on the cube icon that opens the cascade so I click on the cube icon ( in the cascade menu) to finally click on the cube icon that starts the command.
Hi Killian - can you make sure that your toolbar buttons actually have commands at the top level button? (Shift-Right click on the button - you should see something like this:
Hi KIllian - in Options > Toolbar, there is a setting for ‘Cascade delay’, perhaps that is set to zero or a very low number? (number is in milliseconds)
Hi Killian - no… that seems perfectly reasonable. I am at a loss…
@JohnM - do you have an idea? As I understand it, all of Killian’s cascading toolbar buttons at the top level only cascade and never run the command. As if the ‘hot’ triangle covers the whole button…
