Hello everyone, I need some help, I make different models who are walls with an inside cord to join them, the problem is everytime i try to slice it i got problems; “not manifold or extraneous surface”, so i look some repair softwares, but my model get changed and I don’t want that.
I know the other way is to use grasshopper, but i don’t understand the logic way to get the gcode with the model using it, so if somebody has a software or a tip to repair it and get the gcode, it helps me a lot!. Thanks
The simplest solution would be to turn this into one simple solid then use the slicer settings to control wall thickness and infill, none of this hassle is necessary. Otherwise…we’d need to see the model to see what the problem is with it.
Thank you so much, define thickness to the walls help me with the problem, i use the command “offsetsrf” and all was fixed, for my next projects i’ll design it thinking about that, i mean in this case, one side of the walls touch, but the other don’t, so next time i though about that, Thank you all for your comments!.
