Good evening, I’m having a problem with the 3D shaper plug-in… I don’t understand why when I unfold a polysurface, the flat unfolding doesn’t take an x or y coordinate… I’ve attached the gh file so you can see what I mean.
In this case, I flipped it, but when I move it back onto the polysurface, it doesn’t work…
Why was the plug-in written this way? Rhino’s squish orients itself according to a coordinate.
I hope I’ve explained myself well, and thank you in advance.
Nel forum italiano mi hanno suggerito di chiederlo a te #Jessen
ti ringrazio in anticipo.
For ShapeMapping of this 3d object, you can achieve what you need by specifing the Line 0 at the object’s axis of symmetry. I’ve recorded a process for your reference.
Thanks Jessesn, it seems my method was wrong from the start, I created the box and there is absolutely no need for the box… I thank you and I will treasure it… have a good day
