I am after a very simple task, but can’t get my head around what is the problem. I am trying to create a planar surface from 4 curves that I want then to approximate with a mesh. I tried network surface and edge surface but i can’t avoid the surface to self intersect. Would anyone give me a hint about how to solve this? many thanks
Inno, thanks for your reply! Yes, I am too using network surface and yes the layout you tested gives me the same output as yours, but what if you try and use a curve layout much similar to mine? Still getting the self intersect…
