Hello!
After installing Land Design 5.5.1.7117 it is not possible to select VisualArq “object” objects. Also it is not possible to select plants directly by picking object with mouse.
Thanks for help!
Igor
Hello!
Thanks for help!
Igor
Hi Igor,
Does that happen with any model? Does that happen using any specific display mode?
What version of VisualARQ do you have? Check if yo have the latest, and let me know if this problem persists.
If it just happens with a specific model, could you share it please?
Hi Francesc,
RH 7SR10 7.10.21256.17001
VA 2.11.3.15181
LD 5.5.1.7117
Model is big. 67Mb. Is it OK to send you to mail?
Thanks!
Igor
Yes, send it over please. (landsdesign@asuni.com)
Have you tried other display modes, if you have the same problem?
