Problem with script
I have several scripts that use remap to export using the current UCS they export to different file types and all have a sub called ReMapExport.
Private Sub ReMapExport()
	Dim strFilename, strTemplateFolder, strTempFile
	strTempFile = "C:\temp\temp.igs"
	If Not IsNull(strFilename) Then
		Rhino.Command "-Export _-pause " & strTempFile & " _Enter", False
	End If
End Sub
The problem is all the scripts end up using the sub from the last script loaded, so is there a way to make sure each script uses it’s own sub without having a different name in each script.
Thanks Mark
Hi Mark- not that I know of, however you might think about making the one sub with some arguments, inputs, like the file extension, so that it can be called repeatedly
Sub ReMapExport(strFileExtension)
strTempFile = “C:\temp\temp.” & “strFileExtension”
etc etc
and whatever is calling this sub will specify strFileExtension as “igs” or whatever in each case.
Hi Pascal, OK thanks I’ll need to just have a different name for each then. I use some of the scripts to export and start other programs with the exported file, there’s a bit more to some of them.
Thanks Mark.
