Hi!
Please direct me to correct thread if this has already been discussed and solved, I could not find any thread regarding this problem myself on this forum.
I have a coworker that is experiencing some difficulties running a specific plugin (.rhp file)
I can see that the plugin(s) are loaded and enabled in the PackageManager. The corresponding toolbar is prompting the correct command that I can see the plugin wants in the packagemanager.
The problem is that nothing happens after I type the command for the plugin, the command history shows absolutely nothing after the command. It’s like there is no connection between the command and the actual plugin. I should point out I have several other coworkers (myself included) running the exact same plugin without any issues.
I’m having trouble pinpointing where the issue/problem lies. I should also say the plugin is license protected. But I get no errors regarding the license being expired or missing, which has been a problem other times (resolved by renrewing the license).
Thankful for any tips and pointing me in directions I haven’t thought of
