Hi! There is a way to link the figure and the values created to each item into the pulldown menu, like in the attached figure???
I would to chage this elements for each item of pulldown list that I created.
Thanks!!
Yes - do you just want to change the geometry and the values in the fields, or do you want to customize which fields are visible by profile type?
Hi Andrew, the second!
I want to customize the geometry and it’s value for each different profile type included into the pulldown menu.
The way to do this is to swap the geometry in the view with “Set 3d view,” and build the controls you want for each geometry type separately; then use “hide/show elements” to show the appropriate controls for the right object. Here’s an example:
