Hi, I’ve run into a problem, possibly a bug, where the Project Point component won’t find the projection of a point on a mesh, when it should.
The point is actually already on the mesh, however normally the project point returns the points coordinates anyway (it was used to project the vertices of a mesh onto another mesh and in many other cases (vertices already on the target mesh) the component worked correctly.
I found a solution is to use the Mesh-ray component instead, however I thought it could be useful to know about this case, maybe there’s a bug behind it.
I tested it in Rhino 8 SR35 and the latest Beta version.
Thank you!
2026-08-22 - Project Point Problem.gh (175.0 KB)
