I use rhino7 and when I want to print a page (on shaded mode for example) only wireframes are printed !
It is strange that Rhino cannot print what is displayed on a screen.
Is it because my intel graphic hd support only opengl 1.1 ?
Thanks.!
Hi -
You have Vector Output
selected, and that will only print the wires of surfaces. If you change that to Raster Output
, you should get shaded surfaces.
Hi -
Ha, that’s where this comes in, yes…
Please run the Rhino SystemInfo
command and copy-paste the result here.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Education, build 2020-12-08
License details: Stand-Alone
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) HD Graphics (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 11-4-2015
Driver Version: 15.201.1151.1008
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
Hi -
This part shows that the drivers for your Intel GPU are not working.
I’d go to Downloads for Intel® HD Graphics Family to find current drivers and install those.
Thank you @wim but I have already the last version for intel hd 2000 (officially it is not work with windows 10) . I use mesa3d ( Mesa3D For Windows - Federico Dossena ) but it is not very good.
This is a screen capture :
This is now the SystemInfo :
Primary display and OpenGL: Intel® HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y). OpenGL Ver: 3.1 Mesa 20.1.8
OpenGL Settings
Safe mode: Off
Vendor Name: VMware, Inc.
Render version: 3.1
Shading Language: 1.40
Driver Date: NA
Driver Version: NA
Maximum Texture size: 8192 x 8192
Z-Buffer depth: 24 bits
Maximum Viewport size: 8192 x 8192
Total Video Memory: 2108 MB
Hi -
It appears that you are now running Rhino under virtualization (VMware), which is not supported.
When not running on VMware and after you update to the latest Rhino 7 version (7.6 or a 7.7 release candidate), you could try changing the OpenGL level that is used by moving the slider on the Rhino Options > View > OpenGL
page to the left. Try moving one notch to the left at a time. You need to restart Rhino when you change this setting, then see if things improve. If not, move the slider another notch to the left and repeat the process.
And also an “unpaid” version…
