Problem with offset mesh
Hello
I am trying to offset the attached mesh
I need to have an even distance of 18 mm inwards
For some reason this is not happening
You can see in the left side of the image that it gets deformed, i tried using gh (pufferfish and weaverbird) getting the same result
Could you please help?
mesh.3dm (116.4 KB)
shrinkwrap it and use the offset function-
this video may help-
Thank you Kyle
The problem with that method is that it makes the edges smoother
I need sharp edges
I do not understand why offset mesh can not keep an even distance
Best.
You can try Daniel’s face-based mesh offsetting script over here:
See the answer here illustrating why it is impossible to create a constant offset mesh by moving vertices:
Thank you for your help!!!
