I’m having some problems with mapping texture. I downloaded an .obj file and opened it on rhino. It’s a piece o forniture and was made in mm. I need to scale it in meters. I did it but after doing it the texture mapping is lost and I’m not able to edit it anymore, or better, every change I try to make with the texture mapping tools of rhino are not having any effect.
I thought was a problem of the model but I understood was not for that but a problem of the scale.
Here is the render took in mm before scaling
Here after scaling
There is a way to fix it?
