Problem with Loft
Hello guys.
I have problem creating a loft surface between a series of triangular panels
I see there is a problem with the adjacency
Thanks for yiur help
Best
Mario
loft connection.gh (23.4 KB)
missing
Your objective is not clear. Are you aware of the standard component FaceB? (Face Boundaries)
P.S. Are you looking for something similar to this?
loft connection_2024Feb2a.gh (13.8 KB)
Hi Joseph
Sorry not to make myself clear
And thank you for for reply
I am not trying to have a frame on the same plane of the triangle
But to construct the thickness between the original triangle and the one with a 15 mm offset
As seen in the sketch
If i connect a loft with those 2 join curves it does not work
Thanks again
I can’t see what your file is doing as long as you use that plugin. Something like this perhaps? The purple group culls the faces that are perpendicular to Y, ignoring faces on the edges.
loft connection_2024Feb2b.gh (17.5 KB)
Instead of loft, maybe you want extrude? (see the other green group)
Thanks Joseph
Will try that asap
Best
M
I think this is what you’re trying to accomplish.
240202a_loft_connection.gh (15.7 KB)
Like your file, this uses the Offset Mesh component from the Pufferfish plugin.
-Kevin
Thank you so much Joseph and Kevin!
Kevin that is what i needed!!!
I will use your method
Still, i do not un derstand why mine did not work
Thanks again to both of you
Best
M
The reason why it doesn’t work is because Deconstruct Brep does not deconstruct the two breps the same way (I’m not able to say if it’s supposed to work like that or it’s a bug or a feature -there are open threads on this matter- I just learned to not rely exclusively on it, and use topology/adjacency/something else when needed)
for instance, edge index 23 of the first brep and edge index 23 of the second brep are not what you expect:
if you wanna see the things highlighted in this screenshot, here is the file: loft connection_deconstruct_brep_behavior.gh (23.3 KB)
the nice solution posted by Kevin bypasses the problem entirely :+1:
hi inno
thanks for the explanation!
it is good to know that deconstruct brep does not work as expected
best
m
well, to be fair we can’t say those two breps are the same brep either :smiley:
