Problem with jpeg/jpg suffix
i have to rewrite every file with the suffix jpeg to jpg that i can drag and drop it into rhino. maybe it should just read it?
Thanks for this report… just got to dig into it and I filed https://mcneel.myjetbrains.com/youtrack/issue/RH-62415 for the developers. In the meantime, I found you can open the Textures panel and with the + button add jpeg files as bitmap textures. You can also run the Picture command and that works for jpeg too if that was the ultimate goal.
getting the file to work is not the issue, just the inconvenience for not being able to drag and drop it.
I have just fixed RH-62415 and RH-62417. The fixes will be available in version 7.4.
John
