A couple of things about the hatches.
If I remember correctly, in the past, Brep added to the wall by Add Solids was hatched similar to the wall, now it doesn’t.
Regular Rhino Hatches have convenient functions like Basepoint and also they are aligned to the object. So if I have a nicely positioned hatch, moving the object doesn’t destroy it. - VA Hatches are world aligned which is troublesome with not uniform hatches. World aligning can be good to have nice transitions between multiple objects, but object aligning has its advantages also, so maybe some aligning toggle?
- Is it possible, that some overlapping functions like hatching would not be doubled (Rhino and VA subpanel) and they will share all their functions?
Editing Brep with Section Attributes resets them.
Is there a chance to add GH component which would set Section Attributes to the baked geometry?
I started a thread about baking issues ( Expanded baking options in vanilla GH) where I write also a bit about hatches. Besides problems with BakeName & Elefront compatibility, now if I want to bake custom geometry with hatch patterns I got to pretend that they are all Walls and use Wall From Solid component.
What if I want to bring e.g. Stairs from Revit and bake them hatched?
