Problem with group content
The group content is not working well with User text key values. The pull down menu brings up a $ sign which does not allow any grouping…the only solution I have found is to leave the value as UserText and input a category with text.
Hi Giusseppe,
Can you provide your systeminfo as welll as example & steps to repeat. I tried to repeat in a quick example but everything looks ok. Thanks
R8-UserText-Grouping.gh (15.4 KB)
TEST-USER-TEXT-INPUT.gh (10.0 KB)
test user text input.3dm (2.8 MB)
SYSINFO.txt (5.1 KB)
the problem is with the selection of a branch of usertext within the group content.If I choose UserText in the drop down list and then choose a branch from that list such as UserText$METAL the component does not group anything .It only works if I leave the Key as UserText and input a seperate panel with METAL…maybe you have changed the content components since the examples for grouping were published. If I work with the filesgroupingandfiltering from Rhino - Grouping and Filtering Data
the component works as expected but I see that instead of the branches of UserText having a dollar sign they have square brackets.However if I choose a different branch from the drop down list it reverts to the dollar sign.
in another of the examples there is another component used which does not appear to be present in Grasshopper 1.0.0008
Hi @giusseppe,
This is a bug only affecting macOS version.
It will be fixed on next 8.17 RC of Rhino.
Thanks for reporting.
thanks for letting me know…I have been going around in circles trying to figure out what is wrong…
I see that group content is fixed…thank you…I still cannot locate this component…
I think this component eventually became replaced by ‘Filter Content’ component.
oh, so you now plug all the rules into the filter input…
Maybe a couple of the feature pages for ver. 8 should be updated because that is where I saw that component.
Are there specific documents that are outdated? The guide I’m showing here seems to have the correct version of the components. And I can’t find any guides that show the component you showed that include the “rule” input. Are you using the latest version of Rhino/GH?
Hi Andy…One of your references is on
Trying to set UserText to a grasshopper model object (GH_ModelObject)
discourse.mcneel.com
](https://discourse.mcneel.com/t/trying-to-set-usertext-to-a-grasshopper-model-object-gh-modelobject/161131/13)
I cannot find the other place that you mentioned a filter by rule and I took that screenshot because I couldn’t find the component.
Ok. Thanks for the link. I’ll have to add an update to say that the post has been updated to new components. Cheers.
