Why the fillet smaller edge (ie the cross) to 1.5 (and above) is performed, while, with values less than 1.5 fails?
In addition, the shelling of the rear face (the face with red border) always fails.
you can better control this kind of situations, both with fillet edge that with the shelling?
I tried with different tolerance values (0.05, 0.001); Sometimes the fillet edge only works for a certain value, increasing or decreasing the size of the fillet sometimes it works, sometimes not.
I think it should be revised.
You can test yourself on my file and you will not always work, indeed, hardly ever!
This example is part of the special cases, in which Rhino still struggling a little.
At times with radius 1 works, the works setting it to 2 times, and other times operates below of 1 …
It 's too frustrating!
Yes, you’re right, maybe tolerance is a little low. I tried with 0:01, but even in this case the fillet edge over 1 does not work. If imposed a radius of 0.8, for example, the fillet works, but the shell of the rear face does not work over 1.
Try it please. problem fillet and shelling.3dm (140.2 KB)
Excusme, I wanted to write “tolerance 0.001”.
how do you know what is the limit where the fillet edge (and shell) works?
If I set a radius of 1 works, if required 1.1 no longer works.
This also applies to certain values of thickness (in the shell)
