Problem with designation in DWG/DXF
Hello, I have a Total Station that received an update. Since the update, the point labels are no longer displayed in Rhino. When I open the export with the Autodesk Viewer, the points are present.
ALEX TERASSE.dxf (133.3 KB)
is it a proxy entity?
Hi A -
Could you clarify what you mean by this?
In the meanwhile, I’ve put this text annotation issue on the list of the developer.
RH-83577 File IO: No Text on DXF Import
Yes. But before the update, it was working with Rhino.
CARPORT.dxf (168.3 KB)
An example file before the update.
this is a Surveying device from Hilti PLT400-4 This Device
Thanks.
I’d recommend looking into the export options in the software that comes with that device. That way, you wouldn’t have to wait for a change in a Rhino version.
Unfortunately, there’s nothing I can adjust there. I’ve now installed Rhino 6. That’s sufficient for now. Thanks.
it looks like before the update it was block referance. Did it turn into proxy entity after update?
if it did I usually explode it in the autocad then import it into rhino.
