Problem with creating a printpath
Hello everyone, I am trying to create a printpath using contours + divide curve + polyline, but the polyline that results has some open spaces which shouldn’t be there. Has anyone encountered this problem? Do you know how to fix it?
Thanks a lot,
Gloriana
This works, thank you so much :slight_smile:
I am still getting a very weird printpath though - it should be a continous spiral.
Do you maybe know why this could be? I am following the script from the book “Advanced 3D printing with Grasshopper”.
Hello
without a script it will be hard to help. There is probably a DataTree mismatch
spiral.gh (8.4 KB)
spiral.3dm (2.5 MB)
Here are the scripts :slight_smile:
More simple with a script
You need to flatten the data in order to have a list and put false at closed because it is an open path
spiral (1).gh (7.4 KB)
Thank you so much!! :slight_smile:
