Hello!
I’m simply trying to create a hatch from a curve (a simple test rectangle), but get this error.
Any hints?
Thanks a lot!
Hello!
Any hints?
Thanks a lot!
That hatch parameter is from a different plugin. The “CreateHatch” component should be all you need. You can visualize the geometry (surface or curves) in the HG output, or you can bake the hatch to rhino by setting “B” to true.
Thanks, got it.
Thing is, I wanted to use it as a replacement for the VisualArq hatch component inside a vaElement GH definition, because it seems to have a bug. To get the vaElement to work, a GH script has to terminate with a geometry parameter.
However, I’ll leave it at that and wait for them to fix it.
Thanks a lot!
