Problem with cluster output
Hello
I’ don’t vunderstand why the panel output within the cluster:
is not the same as the output outside the cluster:
Did I miss something?
It looks like the path is also different. Have you made some copies of the cluster?
It could be the case that you are outputting the macro headers and footers before the other text is inserted in another cluster. If so, you can right-click one of the clusters and select Disentangle.
If not, I’m not sure what’s happening without looking at the definition.
Thank you for your answer
after manipulations, it is indeed probably a problem of path manipulation, although I don’t really understand the relationship with this problem of cluster output…
