Hi, your mesh input for the meshloads has very large faces, therefore the loads are not distributed to all your shell points. You need to increase the resolution of the mesh. Here is one example:
Make sure all elements are split at their intersection. For examples your columns and beams are not split correclty.
Also if you want to apply ribs to your floorplates, the beams also need to be split according to your mesh, please see Karamba3D Tidbits #24 Shells and Beams
However, because of the subdivision of the elements, when I try to analyze the beam forces at a certain parameter ts, it is referred to the SUBdivided element. Is there any way to query for the original element and its parameter?
Hi, currently there is not an easy way to do this. Here in this example we show a workaround: Moving Pointload on Cantilever - Karamba3D but this is something that we are trying to implement natively.
