Problem with a SubD rendering
Hello, I have a problem with my SubD surface as you can see on the attached pictures. I can’t get a logical result with the Display Invert button. Do you know why and can you help me?
Thanks in advance.
Uploading: Capture d’écran 2022-07-08 à 18.01.06.png…
Uploading: Capture d’écran 2022-07-08 à 18.01.23.png…
Uploading: Capture d’écran 2022-07-08 à 18.01.30.png…
Hi Melvin - please try attaching the images again, only one of the three shows, here.
Uploading: Capture d’écran 2022-07-08 à 18.01.13.png…
I hope it works this time. Good to see you.
Hi @Melvin
It looks like there’s a single edge segment there that isn’t creased, but the others are. Use the Crease command for this, and it should look right.
HTH, Jakob
Perfect, thank you very much, have a nice day.
