Greetings!
I’m attempting to transform a 2D pattern so that it’s evenly distorted within a 2D closed curve.
I tried using the ‘Flow’ command, with the pattern’s closed rectangular border for the ‘Base Curve’ & the closed ‘Target Curve’. This results in the first screenshot.
When I isolate a single open curve as the Target, this results in the second screenshot.
Seems like there may be a simple solution that I’ve missed… I’d like to avoid distorting manually using CageEdit
Thanks in advance!
