Problem uninstalling Rhino.Inside.Revit
I tried to unsitall Rhino.Inside.Revit, but it says cannot access network location. I have already uninstalled Revit 2023 and installed Revit 2024. I have also deleted the Rhino.Inside.Revit files from Program Data Addin folder and deleted Revit 2023 from regedit but still doesnt work
Hi Milind,
Was Revit installed in the default location or a custom one?
Manually removing some of the files is most likely the issue. Have you tried the Microsoft uninstall tool?
