Hello Guys i hope you can Help me,
i Import Templates with my script and my problem is that i use the Default Dim Style for that.
Here is my Test Code to Remove the Default Dim Style and Import that from my Files.
rs.AddDimStyle("Dummy")
rs.CurrentDimStyle("Dummy")
rs.DeleteDimStyle("Standard")
And here ist the Error i get from the Debug Console:
Message: 'DimStyleTable' object has no attribute 'DeleteDimensionStyle'
Traceback:
line 219, in DeleteDimStyle, "C:\Users\PidollA\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\dimension.py"
line 4, in <module>, "C:\Users\PidollA\AppData\Local\Temp\TempScript.py"
I Hope someone can Help me with this Issue.
Thanks
That actually looks like it might be a bug in rhinoscriptsyntax. For the dimension style table, there is no method DeleteDimensionStyle, only Delete.
Just as a test - does the following code work to delete the dimstyle without an error? If not, please post the error message.
import scriptcontext as sc
def DeleteDS(style_name):
ds = sc.doc.DimStyles.FindName(style_name)
if ds and sc.doc.DimStyles.Delete(ds.Index, True):
return style_name
DeleteDS("Standard")
return style_name
rs.AddDimStyle(“Dummy”)
rs.CurrentDimStyle(“Dummy”)
DeleteDS(“Standard”)
This Works well Thank you for the fast Help
OK, that means it is indeed a bug in the rhinoscriptsyntax library. Funny nobody has caught it up to now. The definition I wrote is just a corrected copy of rs.DeleteDimstyle. I will file a bug report.
https://mcneel.myjetbrains.com/youtrack/issue/RH-65174
For now you can use the above definition instead of rs.DeleteDimstyle.
