Hello everyone, I am new to scripting and trying to achieve a random pattern into a surface using two sets of squares, one of 10x10cm and the other with 20x20 cm… I did this script but could only achieve the green geometry in the image, I tried to define the surface corner with the vertice, but i don’t know exactly how to do that
every point that in the grid that did not generate a 20x20 tile can generate a 10x10 tile
small tweaks here and there, like giving the tiles range “1 to 19” instead of “0 to 20” in such a way they won’t be recognised by Collision One/Many if their edges are touching…
Ohhh nice! I wasn’t being able to script in gh because haven’t found the means so I was trying to work around python, but this anemone i never used, seems nice! thanks for the help man!
I wonder how could I get those not used points to generate the 0.1 tile, I think I need to get the rest of the numbers that didn’t get gated, but don’t know how to do it.
i don’t know why, it already achieved the final result I was planning, but I was planning to do this with random reduce in the 10x10 tile. Why some of the 10x10 tile are not appearing after the colision?
tried to plug a random surface on XZ but can’t really say what’s going on
for sure if you want to generate tiles on XZ you should plug a XZ plane and extrude toward Y instead of Z
for more investigation, please upload your GH file with internalized starting geometries (right click on the Surface component and chose “internalize”)
start domain of the big tiles is set to 0
this means that Collision One/Many will prevent any type of tile to be created, if by doing so it will go through that point
