Problem printing PDF from layouts with rendered views
Hi all,
I have made several lay-outs with top/side/front views and perspectives, all with views set to rendered.
When PDF printing these lay-outs some of them make Rhino crash after which the following screen pops up:
%%[ Error: syntaxerror; OffendingCommand: --nostringval-- ]%%
Stack:
/definecolorrendering
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
I have used bitmap images for the materials, on screen it all looks fine.
When I change the views to pen or shaded it prints fine, also
Working with Rhino 6, problem occured while working with a laptop as well as on a workstation.
Being new here I was not sure if I should create a new topic or stick it to an existing post with a more or less similar topic I read, in any case help is much appreciated.
Henk
Hi @henk,
Does it start working if you disable Skylight in the Rendering panel?
-David
Hi @DavidEranen,
Yes it does!
@Henk,
This is a known issue that I’m working on right now. I have already been able to improve the situation, but it will be a while before this fix gets out to everyone.
OK, understood, thanks for now, much appreciated.
