Problem Plugin I think? How do I find which one it is?
Hi Developers
I believe I have a problem with a plugin in Grasshopper. I constantly get the following message when I add new objects to my project, open Grasshopper, or open Rhino:
I am sure this is because two plugins are having issues with each other, as I have a lot of plugins installed. They could also need to be updated, but I honestly don’t know how to check.
Apparently, there is a developer tool that allows you to see if a plugin is valid, but I don’t have access to that.
Please see the attached HTML file and screenshot of the error message. I have sent this message through the “Send” button, but I am not sure if it went through.
Thank you for your time and assistance.
unnamed.html (1.4 KB)
‘.html’ :question: That tells us nothing more than your image. What about the GH file?
Exit & restart Rhino. Then run the _GrasshopperLoadOneByOne command and take note of which plug-in triggers the message you’re getting.
-Kevin
Ok thanks guys. Ill try that and revert.
@Joseph_Oster this happens begore I even launch grasshopper. I can send and empty file but Idont think that will help. Let me try Kevins fix and Ill come back to you. I have already taken up too much of your time this week and I have more questions to ask about other things.
Thanks again!
