I can’t open this file anymore, today I imported some trees blocks from a sell-buy 3d model platform (such as Archive3D or TurboSquid) and I attributed materials to them (from rhino materials NO plug-ins ecc…), then saved the file and now when it opens rhino doesn’t respond (says “creating mesh” but I can’t do anything). Could someone help me solve this please? Thanks!
You might just launch Rhino in “Safe Mode”, open your file, run the “ClearAllMeshes” command, then save it. Close Rhino and re-open it in normal mode. Open your file…
I opened the file in safe mode - it opens, but Rhino is very unhappy - have not found what is causing it yet, I am barely able to interact with Rhino.
There are six bad meshes - trying to delete these but it is very slow.
Hi @FILIPPO_ORLANDI_MANG et al
I checked the file, and the culprit seems to be 90.000+ meshes (the leaves of the imported plants) that are grouped but not joined. When all those meshes are joined, the file is responsive. When dealing with things like plants, it’s vital to try and keep the number of meshes down - join all leaves with the same texture/mapping into a single mesh by starting the Join command and setting JoinDisjointMeshes to Yes. Now select your 15.000 grouped meshes and pres enter. That’ll give a single mesh which is much, much more easy to handle.
HTH, Jakob
