<Problem> Nvidia Geforce RTX 2060-2080 & Rhino 6
Rendering with Raytrace Function with Graphic Card Nvidia Geforce RTX 2060 doesn’t work with Rhino 6
the ray trace work with CPU Only but doesn’t work with GPU (Rhino Option > Cycles
Do You Know About the Problem? there is any solution?
Thanks
Inbal
Make sure correct driver is installed. and reboot after having done so.
I develop using RTX 2070. There was a Windows update just recently, after which I noticed Raytraced couldn’t see the GPU. Driver update and reboot fixed it.
Thanks’ for the Answer, I update the GeForce Driver to up today
A did the Reset
Unfortunately, It’s didn’t work :frowning:
Any Suggestion?
I am on Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 11-7-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.22. If you have a newer driver, maybe downgrade and see if that works?
Hi Nathan,
How to check the Primary display and OpenGL: ?
NVIDIA GeForce RTX 2060 (NVidia) Memory: 16GB
Driver date: 12-10-2019 (M-D-Y)
OpenGL Ver: 4.6.0 NVIDIA 441.22 How to check the?
I update windows and the GeForce Driver today
When I Use Raytraced there is an orange Strip below. It’s written there Rendering but no Cycle Going on
When I switch to CPU, it’s working fine but match slower
Any Suggestion?
Thanks’
Inbal
@inbal1tal, I used the Rhino command _SystemInfo to get that information.
