Problem joining an Arc curve
Hi, I’m a bigginer in Grasshoper, and had get to this problem that I can’t fix and haven’t found a solution.
I built an arc between 3 points, two of are allready used in a joined structure. When I join this arc to the rest of the curves, I’m not able to convert it to a surface, neither extrude it.
Does anyone knows wy this could be happening?
Thanks!
GrasshoperV3.1.gh (14.1 KB)
You’ve got to Flatten the input to Join Curves but you still get two curves, a closed one and the line you also are inputting. I imagine the final extrusion is what you want, so I don’t see what purpose that line serves.
It worked!
Thanks!
